Automatic Backup
DeLaVega1944
Automatic Backup
Post by DeLaVega1944 » Thu Oct 12, 2017 10:51 pm
Does Audacity have an Automatic Backup, if not is there a party program that could do the equivalent as I am recording? Thank you for your response.
Contact:
Re: Automatic Backup
Post by steve » Fri Oct 13, 2017 2:57 pm
It is recommended that you make backups of recordings by (manually) exporting as WAV (or FLAC) immediately after recording. A potential problem with automating this would be that it could cause the hard drive to be busy when Audacity needs to write data from the recording, causing data loss in the recording.
