How to remove annoying explosion sounds with audacity?
Norumbega
Operating System: Windows 7
Post by Norumbega » Thu Oct 12, 2017 4:55 am
This video here has a cool music that I want to extract.
https://www.youtube.com/watch?v=16cewjeqNdw
Sadly, they edited annoying fake explosion sounds over the music that I want.
Here is the sample that I am trying to clean up
https://drive.google.com/file/d/0B0UM2A ... sp=sharing
Is there any way to remove those explosion sounds? I'm no expert in audacity, and googling for a way to remove sounds from audio only leads to tutorials on removing constant background noise, not distinct sounds.
If anyone can help, thanks.
Contact:
Re: How to remove annoying explosion sounds with audacity?
Post by steve » Thu Oct 12, 2017 11:13 am
Norumbega wrote:Is there any way to remove those explosion sounds?
Not without also removing the music.
Norumbega wrote:googling for a way to remove sounds from audio only leads to tutorials on removing constant background noise, not distinct sounds.
That's correct. Constant low level background noise can often be reduced quite well using Noise Reduction effects such as: http://manual.audacityteam.org/man/noise_reduction.html
but you are effectively wanting to "un-mix" the explosion sound which is louder than the music, which by analogy is like trying to un-mix the milk out of a Café Latte (can't be done).
