loop(repeat) audio "while" recording
srikamala99s
Post by srikamala99s » Tue Oct 10, 2017 11:41 pm
Hello Everyone,
Could you please help me with the following situation?
I want to record some audio to learn for chanting purpose. Whatever I say, it should be recorded and repeated again 3 times with low volume.let us say, I say " let noble thoughts come from all directions". Then it should be recorded and repeated 3 times (total 4 times ). The repeated ones should have low volume. So, the audio file should look like :
" let noble thoughts come from all directions {silence} let noble thoughts come from all directions {silence} let noble thoughts come from all directions {silence} let noble thoughts come from all directions {silence}
Then I say something else and that should be recorded in the same way as explained above.
Could you please help me with this? Thank you so much.
Regards,
Sri
Contact:
Re: loop(repeat) audio "while" recording
Post by steve » Wed Oct 11, 2017 12:04 am
Audacity can't do that.
I can't think of any other program that can either. Perhaps a real-time DAW (such as ProTools, Cubase, Reaper, Sonar ...) with a very slow delay effect as an insert effect in the recording channel.
Trebor
Post by Trebor » Wed Oct 11, 2017 2:28 am
srikamala99s wrote:... Whatever I say, it should be recorded and repeated again 3 times ...
A hardware solution ? ... https://youtu.be/Gd0NhglZWtw?t=29s
srikamala99s
Post by srikamala99s » Wed Oct 11, 2017 9:18 pm
My sincere thanks to both of you. I understood the "hardware" solution, but not a professional recorder. Whatever I am trying to do is just for my kids purpose:) but Thank you both again.
Regards,
Sri
