change level ?
rectek
change level ?
Post by rectek » Tue Sep 26, 2017 5:26 pm
I am using Audacity 2.1.3 with a PC, late model. I am transferring all my old cassettes of my music to the computer, and then to CD's.
But some of my old recordings of my playing are not "balanced", that is, one channel is a higher level than the other. (Due to careless mic placement, or whatever.)
Question: Is there a way to increase the level of only the low channel, either during, or after, recording into Audacity?
Thanks in advance for your help
waxcylinder
Re: change level ?
Post by waxcylinder » Tue Sep 26, 2017 6:08 pm
Go to the Track Control Panel of your tack (the box to the left of the the waveform) and click on the little black downward pointing triangle).
This will give you a dropdown menu, choose "Split Stereo track"
This will separate the two channels enabling you to edit either of the independently.
When finished go to the top track and click on the black triangle and choose "Make Stereo Track" - this will combine the two channel tracks back into a single stereo track.
DVDdoug
Forum Crew
Re: change level ?
Post by DVDdoug » Tue Sep 26, 2017 6:17 pm
Or, you can try the Normalize effect and select Normalize stereo channels separately. That will make the peaks equal, but it won't necessarily make them sound equally loud.
...If they don't sound equally loud after normalizing separately, reduce the louder side because you'll have little or no headroom to boost the quiet side without clipping (distortion).
Trebor
Re: change level ?
Post by Trebor » Tue Sep 26, 2017 7:10 pm
rectek wrote:Question: Is there a way to increase the level of only the low channel, either during, or after, recording into Audacity?
Can do that using the pan-slider and gain-slider ...
Pan & gain slider demo.gif (443.32 KiB) Viewed 317 times
then, once balanced, use mix and render to fix the changes.
rectek
Re: change level ?
Post by rectek » Tue Sep 26, 2017 7:36 pm
Thanks !
As they say, "it's easy, if you know how"
Now I know how....
