How to compare spectra of 2 recordings of same event
Henr
Operating System: Windows 7
Post by Henr » Sat Sep 23, 2017 12:51 pm
Hi!
I have 2 stereo-recordings of a speech/discussion event. Since the room was a circular dome, there is a lot of echo in one of the recordings (much less in the other), making the voices difficult to understand. So I want to identify the frequencies of the echo to dampen them. But I can't figure out how to analyse and compare the spectrums of the two recordings in order to identify the echo-frequencies. Both recordings are loaded into Audacity and synchronized in time. I have tried studying Plot Spectrum - http://manual.audacityteam.org/man/plot_spectrum.html - but I can't see how I need to use it.
(Next question would be which Effect to use to dampen the specific frequencies. 8-) )
Thank you!
(I have already improved the sound significantly with compression and noise reduction.)
(I use Audacity 2.1.3 on Windows 7 Home Premium 64-bit SP1)
DVDdoug
Forum Crew
Re: How to compare spectra of 2 recordings of same event
Post by DVDdoug » Sat Sep 23, 2017 7:52 pm
Why not just use the better recording?
Are you using Analyze -> Plot spectrum? You may see a difference between the recordings, or you may not.
In general, you can't remove reverb-echo. The reflected frequencies are, of course, the same as the original frequencies.
But, somebody does make a De-Verb plug-in. It's not free (there is a free trial) and I don't know if it works in Audacity.
Henr
Post by Henr » Sun Sep 24, 2017 10:36 am
The better recording is only better for the main speaker, not for the rest of the participants. So I need to switch back and forth between the 2 recordings.
DVDdoug wrote:Are you using Analyze -> Plot spectrum? You may see a difference between the recordings, or you may not.
I couldn't see ANY difference. So I am wondering if I am using that analysis correctly.
DVDdoug wrote:In general, you can't remove reverb-echo. The reflected frequencies are, of course, the same as the original frequencies.
Yes. That's why I would only dampen them, not remove them completely.
DVDdoug wrote:But, somebody does make a De-Verb plug-in. It's not free (there is a free trial) and I don't know if it works in Audacity.
OK. Thank you! I will take a look at that.
Trebor
Post by Trebor » Sun Sep 24, 2017 1:09 pm
The $80 "spl_de-verb_plus" does work in Audacity on Windows.
This free "transient" VST plugin does something similar ... http://www.vst4free.com/free_vst.php?pl ... nt&id=2153
Henr
Post by Henr » Thu Sep 28, 2017 7:04 pm
Now I have installed the "VST Transient" plugin in Audacity and I have tried using it. But I am a bit puzzled as to how it can help me dampen the echo of the circular dome? Can anyone explain how to use it for that? Thank you!
Henr
Post by Henr » Tue Oct 17, 2017 12:03 pm
I tried the SPL De-Verb plug-in. It didn't have any noticeable effect (and I had to install Reaper to make it work...) So the company advised me to try a professional tool called iZotope RX6 from https://www.izotope.com/en/products/rep ... tures.html . BUT why hasn't anyone pointed out that Audacity has a built-in effect called Reverb?!? I am going to try that now! It looks quite more advanced than the SPL De-Verb plug-in(!)
Post by steve » Tue Oct 17, 2017 12:08 pm
Henr wrote:BUT why hasn't anyone pointed out that Audacity has a built-in effect called Reverb?!?
The Audacity "Reverb" effect creates reverb and adds it to the sound.
"De-verb" effects attempt to remove reverberation from the sound.
Trebor
Post by Trebor » Tue Oct 17, 2017 3:20 pm
Henr wrote:
Trebor wrote:This free "transient" VST plugin does something similar ... http://www.vst4free.com/free_vst.php?pl ... nt&id=2153
"Transient" VST is a dynamic-range-expander : it attenuates the sound when it goes below a threshold ...
''Transient'' is an expander--- attenuating the sound below threshold volume.gif
''Transient'' is an expander--- attenuating the sound below threshold volume.gif (37.15 KiB) Viewed 782 times
It only reduces the reverb a little bit.
Even the most expensive software cannot cure a bad case of reverb.
Henr
Post by Henr » Mon Oct 23, 2017 8:54 pm
I didn't want to 'start all over' with a huge professional tool like iZotope RX6, so I marked about 0.15 sec. of reverb at the end of a man with a deep voice saying a word that didn't end with 's' or 't' or the like, and then I used that as Noise-profile for a normal Noise Reduction with the following parameters: 12,9,3. It's not perfect, but better than nothing. The only strange thing is that it seems to work OK until somewhere near the end of the 1h:20m recording...? Maybe someone opened a door and thus changed the resonance frequencies of the room(?)
