iTunes ignoring my track edits in Audacity
Permanent link to this post Posted by Rew » Fri Sep 08, 2017 9:43 pm
I'm using Audacity ver. 2.0.6 on Windows 10 (and iTunes ver. 12.4.0.119 if that helps).
So I have a couple musical tracks to which I've added about 5 seconds' worth of silence to the end (otherwise they end rather abruptly immediately after the fade-out). I export these tracks as MP3s, but when I play them in iTunes--despite the fact that iTunes lists their run time as 5 seconds longer than their previous versions--iTunes will skip over the bit I've silenced out at the end, going from 0:06 immediately to 0:01 and then on to the next track.
iTunes just straight-up ignores an edit I've made in Audacity! How do I get it to behave?
Rew
Re: iTunes ignoring my track edits in Audacity
Permanent link to this post Posted by kozikowski » Sat Sep 09, 2017 2:05 am
I have this fuzzy feeling I should know this one, but I can't quite catch it.
2.0.6 is really old. Any reason you're not in 2.1.3?
http://www.audacityteam.org/download/windows/
What happens if you open your edited MP3 in a fresh Audacity?
How did you get the silence? Generate > Silence? Generate > Silence only creates mono silence. How did you get to the finished show?
Permanent link to this post Posted by Rew » Sat Sep 09, 2017 5:29 pm
So I've just updated to the latest versions of *both* Audacity and iTunes. I exported both tracks again, in the new Audacity to the new iTunes. And I *still* have the same problem. iTunes will skip from the 0:07 to the 0:01 mark, without fail.
Strangely enough, both tracks work just fine when I play them in Winamp. Only iTunes is giving me this problem.
To your other question--yes, I used "Generate > Silence." Is that not the way I'm supposed to do it? Is there a better way to create a few seconds' worth of silence at the end of a track?
Rew
Permanent link to this post Posted by steve » Sat Sep 09, 2017 6:08 pm
Rew wrote:Strangely enough, both tracks work just fine when I play them in Winamp. Only iTunes is giving me this problem.
Pretty good evidence that your Audacity edits are exactly as you intended, and the problem is iTunes. Sorry I'm not able to help you with iTunes as I avoid that program like the plague.
Worth considering:
A good, free and lightweight audio player for Windows is "foobar2000". It's not much to look at, but it is excellent at doing what it was designed to do, which is for playing audio (it is also very useful for converting audio formats and applying "ReplayGain")
If you want your audio player to manage your music collection, "Clementine" or the free version of "MediaMonkey" are worth looking at.
Permanent link to this post Posted by Rew » Sat Sep 09, 2017 6:58 pm
Ah, I was afraid of that.
The main thing I use iTunes for is creating large 100+ track long MP3 CDs. (Yes, I know that's very 2005 of me. I still like it that way though. :P)
Do any of the programs you listed have an option for burning MP3 CDs? I'll gladly ditch iTunes if so!
Rew
Permanent link to this post Posted by kozikowski » Sat Sep 09, 2017 7:02 pm
Where did the original tunes come from? iTunes pays attention to copy protection. You may have confused the FairPlay system.
Permanent link to this post Posted by kozikowski » Sat Sep 09, 2017 7:04 pm
If you're in Windows 10, Windows Media will burn a CD.
Permanent link to this post Posted by steve » Sat Sep 09, 2017 7:22 pm
Rew wrote:Do any of the programs you listed have an option for burning MP3 CDs?
Foobar2000 can convert most audio formats to MP3.
An "MP3 CD" is just a plain old data CD with MP3 files on it, so just about any CD burning program can do that. In fact I think you can burn CDs directly from "File Explorer".
I rarely use Windows, but these steps look reasonable: https://support.hp.com/gb-en/document/c03453031
Permanent link to this post Posted by steve » Sat Sep 09, 2017 7:25 pm
Of course Audacity can export as MP3 if you have LAME installed (http://manual.audacityteam.org/man/faq_ ... .html#lame)
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], Google [Bot], Wim4 and 13 guests
