time shift of single part in single channel
Permanent link to this post Posted by arahav » Fri Sep 08, 2017 6:09 pm
hi
new to audicity
i have selected 2 songs and i want to make time shift of specific seletion in only one of those tracks.
could not find how i can do it.
thanks for help
arahav
Re: time shift of single part in single channel
Permanent link to this post Posted by kozikowski » Sat Sep 09, 2017 1:57 am
First pass and without knowing what you're really doing, you should probably not be on one track. Import both songs and they should appear one above the other and try to play at the same time. Use the Time Shift Tool (two sideways black arrows) to push the bottom track to the right (later) until it gets to where you want it to be. Use can use other tools to fade in and fade out, change volume, etc. etc to either track to achieve a match.
Did I hit it?
Return to Windows
Who is online
Users browsing this forum: DVDdoug, nickybail and 19 guests
