getting going!
getting going!
Permanent link to this post Posted by marc roman » Fri Sep 08, 2017 2:56 pm
I have connected a turntable to my computer via usb. I am not getting any sound from the turntable. I am sure I am doing something stupid.
windows 7
audacity 2.1
marc roman
Operating System: Windows 7
Re: getting going!
Permanent link to this post Posted by DVDdoug » Fri Sep 08, 2017 3:29 pm
Make sure to select the USB device as your Recording Device, and plug-in the turntable before starting Audacity.
(Sometimes Windows will automatically switch to the USB device for playback, which of course doesn't work with a turntable, so check to make sure playback is still through your speakers.)
DVDdoug
Forum Crew
Re: getting going!
Permanent link to this post Posted by marc roman » Sat Sep 09, 2017 9:42 am
thanks,doug.
unfortunately that didnt work.
not sure in which order you are suggesting. should I set the parameters you suggest in Audacity or somewhere else and then start Audacity?
marc roman
Re: getting going!
Permanent link to this post Posted by DVDdoug » Sat Sep 09, 2017 3:07 pm
OK, you said you're not getting any "sound"... When you click the Record button, what happens? Do you see activity Audacity's meters and do you get a waveform? Are you recording silence ( a "flat line")?
DVDdoug
Forum Crew
Re: getting going!
Permanent link to this post Posted by marc roman » Sun Sep 10, 2017 11:57 am
a flat line.
marc roman
Re: getting going!
Permanent link to this post Posted by marc roman » Sun Sep 10, 2017 12:08 pm
sorry,replied incoreectly before.
I see activity meters.
marc roman
Return to Windows
Who is online
Users browsing this forum: No registered users and 10 guests
