Automatic set overlap
Permanent link to this post Posted by fas723 » Wed Sep 06, 2017 7:00 pm
Hi,
I'm have just stareted using Audacity and I'm just finished editing a few songs with 5s crossfades in both ends.
Now I would like to import them all at the same time and put them in line with a given number of secound overlap. Much like the feature: Tracks->Align tracks->End to End, but just not End to End, rather "End to End with Xs overlap".
I have been looking in the FAQ and various google/youtube searches but no luck.
Is there such feature?
Thanks!
fas723
Operating System: Windows 7
Re: Automatic set overlap
Permanent link to this post Posted by steve » Wed Sep 06, 2017 7:11 pm
No there is no automatic alignment with overlap.
However, considering what you are doing, are you aware of the "Crossfade Tracks" effect? http://manual.audacityteam.org/man/cros ... racks.html
There is also a "Crossfade Clips" effect which may be a bit quicker to use, though less flexible: http://manual.audacityteam.org/man/crossfade_clips.html
Permanent link to this post Posted by fas723 » Thu Sep 07, 2017 8:31 pm
Thanks!
Yeah, I know. It is Crossfade tracks I have used.
Problem now is that I have 100-200 songs I need to mate in a good way. Had hoped that there was a better way then using the Time shift tool for each signle one of them...
Well thanks agian for your reply. And I anyone figure out solution for me, please let me know.
fas723
Permanent link to this post Posted by steve » Fri Sep 08, 2017 1:58 pm
Some media players can crossfade tracks automatically when playing (for example Foobar 2000)
Return to Windows
Who is online
Users browsing this forum: mark70 and 24 guests
