Click track help.
Click track help.
Permanent link to this post Posted by BUCK DAFT » Tue Sep 05, 2017 11:02 pm
Hi,
Currently getting to grips with the new version. When I record a stereo track, great no probs. But if I set up a click track silence......I hear nothing.
Mess around with some settings and when I go to record, a red line and arrow appear at the start of the new track and nothing :roll:
I bet I just need to adjust something.......where would be good place to start ?
Windows 10 & a Presonus audio box USB.
Thanks
BUCK DAFT
Re: Click track help.
Permanent link to this post Posted by kozikowski » Tue Sep 05, 2017 11:38 pm
By that you mean Generate > Click Track?
Do your settings look something like this:
Screen Shot 2017-09-05 at 16.34.57.png (73.65 KiB) Viewed 413 times
And timeline look like this when you get done?
Screen Shot 2017-09-05 at 16.36.38.png (12.13 KiB) Viewed 413 times
Where do we lose it? The click track settings I believe are default. I've never used it, so I think those are the factory settings.
Permanent link to this post Posted by BUCK DAFT » Wed Sep 06, 2017 8:24 am
Yes matey. Hit play and I can hear the click, then if I hit record silence . :cry:
BUCK DAFT
Permanent link to this post Posted by steve » Wed Sep 06, 2017 8:43 am
Is "Overdub" enabled in the Transport menu?
"Overdub" must be enabled (on).
"Software Playthrough" must be disabled (off).
Permanent link to this post Posted by BUCK DAFT » Thu Sep 07, 2017 8:30 am
Narrowed the problem down, if I select the computer speakers it records fine. If I select the audiobox to monitor the track it doesn't record.
Strange, any ideas ?
Thanks,
Paul
BUCK DAFT
Permanent link to this post Posted by steve » Fri Sep 08, 2017 8:10 am
Please describe, step by step, what you are going, and what the problem is. Imagine that we can't see your computer (we can't) and walk us through reproducing the problem.
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 9 guests
cron
