Sliding Time Scale/Pitch Shift Reducing Vocal Audio Quality
SnoCone
Post by SnoCone » Wed Aug 30, 2017 5:24 am
I'm using Windows 10 version 1607, Audacity 2.1.3, and used the .exe installer.
I was using the Sliding Time Scale/Pitch Shift tool to make a song gradually get about 10% faster. However, I noticed that whenever I used the tool, the sound quality for the vocals dropped significantly. I've included a small audio sample that has the original and then a 1% change on the tempo using the Sliding Time Scale/Pitch Shift tool. I found that the quality drop was persistent through different sizes of tempo changes (even 0%). I've also tried it on a few other tracks and noticed that it tended to affect vocal-heavy tracks the most, but not consistently.
Does anyone know why this could be happening or a way to avoid or fix it?
sound quality problem.wav
First half is the original, second is the altered
(1.78 MiB) Downloaded 36 times
Re: Sliding Time Scale/Pitch Shift Reducing Vocal Audio Qual
Post by steve » Wed Aug 30, 2017 10:37 am
I think it's just a limitation of the time-stretch algorithm, and that hearing tends to be extremely sensitive to quality changes in human voices (more so than other sounds).
