cannot record a copy of my song
Trebor
Re: cannot record a copy of my song
Post by Trebor » Thu Sep 07, 2017 2:34 am
rjb100 wrote:in ''command prompt'' i have tried to 'rename' and 'ren' the file but i get error message ''command syntax is incorrect''
I didn't rename the config files via "command prompt",
I just went to the (normally hidden) AppData folder, and renamed them there.
rjb100
Post by rjb100 » Thu Sep 07, 2017 9:09 am
trebor
thanks for your help and patience but i am making no progress and will have to give up on my attempt to load your recommended chorus plugins [ i am unable to find my way clear to continue ]
rj
Trebor
Post by Trebor » Thu Sep 07, 2017 11:48 am
It's heresy to mention it here, but there are other free audio editors which are more user-friendly than Audacity,
e.g. OCENaudio which has built-in chorus effect & can accept VST plugins.
Unlike Audacity, OCENaudio doesn't do multi-track editing : Just one stereo-track.
rjb100
Post by rjb100 » Tue Sep 12, 2017 9:11 am
trebor
with regard to the info you passed on to me in your last post..........it was good info;thanks.
i would like to add some things i have learned about loading effects plugins into audacity.
1. i have d/loaded two effects ...chorus and vocal harmoniser into my downloads folder[ they appeared as zip files].
2. unzipped them with windows utility.
3. opened them [ they showed dll at the end which i am told is good]
4. r/c c: disk > program filesx86 > audacity > plugins.
5. from the folder containing the effects files i grabbed them and inserted into 'plugins'
6. in audacity i opened add/remove manager and the effects were in the 'new' box waiting to be enabled.
the chorus is great but i am having no luck with the harmoniser.
it is called 'pitchproof' and i have tried varied and numerous settings but i cannot get it right..... am wondering if this was designed for guitar not vocal[ it was recommended though]
Trebor
Post by Trebor » Tue Sep 12, 2017 12:47 pm
rjb100 wrote:... the chorus is great but i am having no luck with the harmoniser. it is called 'pitchproof' ...
Not all VST plugins will work in Audacity : only "VST2" (not VST3, nor VSTi),
and only 32-bit versions, (even if your OS is 64-bit).
pitchproof does work in Audacity 2.1.3. ...
''PitchProof'' (32-bit, not 64-bit) on Audacity 2-1-3.gif (1.4 MiB) Viewed 694 times
Install the "32-bit"version, not the "x64" bit" version.
There's a (non-exhaustive) list of plugins known to work in Audacity here .... http://wiki.audacityteam.org/wiki/VST_Plug-ins
rjb100
Post by rjb100 » Wed Sep 13, 2017 7:40 am
pitchproof is working in the sense it is responding to any changes to settings .......i just cannot seem to get the simple straightforward harmony/duet type setting.
i checked out your link to the effects lists ....no harmoniser found there.
would it be advisible to start a new thread for pitchproof info !!
rj
Trebor
Post by Trebor » Wed Sep 13, 2017 11:32 am
rjb100 wrote:... i checked out your link to the effects lists ....no harmoniser found there.
Kerovee is a free VST which can do pitch-correction, (aka auto-tune), & has 2 channels so can do duet/trio ...
https://youtu.be/XT_WYjZnU4U?t=42s
Bear in mind it's old & a freebie : there are better VSTs but they co$t.
