cannot record a copy of my song
Re: cannot record a copy of my song
Permanent link to this post Posted by Trebor » Fri Sep 01, 2017 6:32 am
rjb100 wrote:... i have moved the multi voice chorus to audacity add/remove but it will not remain enabled,,,,,,,it goes back to disabled after clicking ok.
i cannot move the bluecat chorus to audacity......it does not show in add/remove boxj
They both work for me ...
Multi-voice-chorus in Audacity 2-1-3.png (22.03 KiB) Viewed 620 times
Blue cat chorus VST is Audacity 2-1-3.png (21.94 KiB) Viewed 620 times
You could have this problem ... viewtopic.php?p=323458#p323458
Trebor
Permanent link to this post Posted by rjb100 » Sat Sep 02, 2017 8:20 am
i tried your link to the possible solution but could not proceed.
i could not locate the pluginregistry.cfg. after following the instruction User\<Username>\AppData\Roaming\Audacity\
if i could find this i will try:
1. exit audacity
2. delete effect plugins
3. reinstall chosen plugins [add/remove location].
rj
rjb100
Permanent link to this post Posted by Trebor » Sat Sep 02, 2017 12:03 pm
rjb100 wrote:i could not locate the pluginregistry.cfg. after following the instruction
"AppData" is a hidden file in Windows.
At the risk of stating the obvious, you have to put your own username in that string without the <> brackets ...
one way to see AppData folder.png (57.29 KiB) Viewed 608 times
Trebor
Permanent link to this post Posted by rjb100 » Sat Sep 02, 2017 7:38 pm
''show hidden files and folders'' is enabled.
i am still unable to find pluginregistry.cfg.
the ''run'' instruction is followed by a ''location cannot be found'' message.
rj
rjb100
Permanent link to this post Posted by Trebor » Sun Sep 03, 2017 4:22 am
rjb100 wrote:''show hidden files and folders'' is enabled.
If you can make your way to "AppData\Roaming\Audacity" "pluginregistry.cfg" is there, see ...
''pluginregistry cfg'' in Windows Vista.png (111.4 KiB) Viewed 596 times
Trebor
Permanent link to this post Posted by rjb100 » Tue Sep 05, 2017 7:43 am
i did a command prompt and it showed there is a plugintegistry.cfg file in c:disk ; i just cannot find it.
however, i have found out i can delete this via command prompt route.
so, just to be sure i am doing things correctly after deletion, can you confirm:
1. i exit [not uninstall ] audacity
2. delete file
3, open audacity and re install plugins of choice including new ones in add/remove plugin manager.
rj
rjb100
Permanent link to this post Posted by Trebor » Tue Sep 05, 2017 7:59 am
rjb100 wrote:1. i exit [not uninstall ] audacity
2. delete file
That sounds right to me.
rjb100 wrote: exit [not uninstall ] audacity
I think the config file will survive uninstalling Audacity, that's why you have to seek & destroy it.
BTW you can rename the old config file, rather than deleting it , as I have done ...
That allows you to put it back the way it was.
Trebor
Permanent link to this post Posted by rjb100 » Wed Sep 06, 2017 7:28 am
trebor
i am not sure i understand your last piece of info.
do i :
1. not go ahead and delete the cfg file via command prompt...... and:
2. rename the cfg file via command prompt
3, if so how do i do this??
will i then be able to locate and load the chorus plugins?
rj
rjb100
Permanent link to this post Posted by Trebor » Wed Sep 06, 2017 8:18 am
rjb100 wrote:2. rename the cfg file via command prompt
If you delete "pluginregistry.cfg" the data in it will be lost : no way back from that, unless you have a copy of it.
If you rename "pluginregistry.cfg" to say "pluginregistry-old.cfg" Audacity will generate a new "pluginregistry.cfg" when it is restarted.
If in the future you need to reinstate (or inspect*) the old cfg file you have a copy called "pluginregistry-old.cfg"
[ * it's a list to remind you of all the of all the plugins you've installed ]
Trebor
Permanent link to this post Posted by rjb100 » Wed Sep 06, 2017 10:22 pm
in ''command prompt'' i have tried to 'rename' and 'ren' the file but i get error message ''command syntax is incorrect''
rj
rjb100
PreviousNext
Return to Windows
Who is online
Users browsing this forum: No registered users and 13 guests
