Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Roash
Post
by Roash » Tue Aug 22, 2017 2:40 pm
Hi all.
I use Audacity for Podcast editing. I need that low whispers volumes are boosted and loud screams are made lower. Basically i need a more "uniform" volume. SOme tutorials told me to use Normalize, but it just change the whole volume to the set. For Now i use and external software called The levelator. There is way to do it using Audition?
thanks all !!
Post
by kozikowski » Tue Aug 22, 2017 4:15 pm
Neither Amplify nor Normalize do what most people want. They're simple, brain-dead tools.
You might like Chris's Compressor. Chris wrote it so he could listen to opera in the car.
https://theaudacitytopodcast.com/chriss ... -audacity/
I use it to tame
somebody else's podcast. I change the first value, Compress ratio, from the default 0.5 to 0.77. When I do that, the show sounds like the local radio station.
Roash
Post
by Roash » Wed Aug 23, 2017 11:02 am
Perfect !! This is exactly what i need thanks bro !!
- Site Admin
Post
by steve » Wed Aug 23, 2017 11:47 am
Roash wrote:SOme tutorials told me to use Normalize
They were wrong.
For information about Normalize (and Amplify), see:
http://manual.audacityteam.org/man/ampl ... alize.html
Roash wrote:I need that low whispers volumes are boosted and loud screams are made lower. Basically i need a more "uniform" volume.
That is called "dynamic range compression" (often just called "compression", though not to be confused with "data compression" which is used to make files smaller).
Levelling out a range of "whispers" and "screams" requires extreme compression, which will inevitably be fairly low sound quality and there will be a substantial increase in noise when the volume of the whisper is brought up. If you need a "stronger" effect than Chris's Compressor, you could try this plug-in:
http://forum.audacityteam.org/viewtopic ... 79#p194179 (note that if your tracks are very long, this plug-in will need to be applied to sections of no more than about an hour).
