Hello!
Im new in this forum and Im also a happy amateur and just recorded my own vocals to an instrumental track in Audacity 2.1.3.0 but I cant export and save the tracks. I tried to find out what version of Windows I use but dont know how to find that information. Anyone patient around that would like to help me get this done? It would be greatly appreciated.
Sincerely
Annika
Export audiofiles in Audacity 2.1.3.0 [SOLVED]
Re: PLEASE Help! Export audiofiles in Audacity 2.1.3.0
Can you give us some more details?
Do the tracks play in Audacity? Did you save the Audacity project?
What format are you trying to export to? WAV is usually foolproof, so try WAV if you haven't already.
What happens? Do you get an error message? Do you get a silent file?
Thank you so much for replying, I figured it out evetually (not exactly sure how I dit it though) but thanks again for responding
Re: Export audiofiles in Audacity 2.1.3 [SOLVED]
I'll mark this topic as "solved", and for the benefit of anyone searching for help exporting audio, here is the appropriate part of the manual: http://manual.audacityteam.org/man/exporting_audio.htmlA.Nick wrote:Thank you so much for replying, I figured it out evetually (not exactly sure how I dit it though) but thanks again for responding
