Hello,
I would like to know how to do the following automatically: Import all files in a folder, add an effect with certain parameters, and export all files with the original names into another folder or overwrite the original files.
Processing Multiple Files Automatically
Re: Processing Multiple Files Automatically
That sounds like Chains, Audacity's Batch program.
http://manual.audacityteam.org/man/chai ... ation.html
