Audacity crashes 3-5 seconds after opening
FL2070
Post by FL2070 » Fri Aug 18, 2017 10:53 pm
As I am rather new to Audacity crashing, I do not know where to find crash logs, but here is my problem:
Every time I open Audacity, it closes itself after 3-5 seconds. I was using version 2.1.2, and I checked the website to find 2.1.3 was released, so I uninstalled 2.1.2 and installed 2.1.3, but the crashes continued. I am running 64 bit Windows 10. I'm sorry I can't provide more information. Where are crash logs generated, if at all?
Re: Audacity crashes 3-5 seconds after opening
Post by steve » Sat Aug 19, 2017 12:13 am
Try reinstalling 2.1.3 and select the option to "Reset Preferences" when that option appears.
On first launch, confirm that you want to reset preferences.
What happens then? Does it crash?
FL2070
Post by FL2070 » Sat Aug 19, 2017 2:29 am
I don't see a reset preferences button, but yes, it still crashes after a complete reinstall.
Post by steve » Sat Aug 19, 2017 9:13 am
FL2070 wrote:I don't see a reset preferences button, but yes, it still crashes after a complete reinstall.
Resetting preferences is the important step. Reinstalling without resetting preferences is unlikely to make any difference.
If you are using the .exe installer on Windows, then there is a checkbox option during the installation process. Re-install again and be sure to read each dialog screen and check (tick / confirm) the option to reset preferences.
FL2070
Post by FL2070 » Sat Aug 19, 2017 8:23 pm
As for resetting settings, will deleting the audacity folder in Appdata/roaming do?
Also, I've discovered something strange. When run on one user, Audacity works, but when run on another user, it does not.
Post by steve » Sat Aug 19, 2017 11:56 pm
FL2070 wrote:As for resetting settings, will deleting the audacity folder in Appdata/roaming do?
I have already given my advice. You are of course free to ignore it.
FL2070
Post by FL2070 » Sun Aug 20, 2017 3:12 pm
I'm sorry, I forgot to mention I don't use the installer due to permissions issues.
Post by steve » Sun Aug 20, 2017 3:18 pm
FL2070 wrote:I'm sorry, I forgot to mention I don't use the installer due to permissions issues.
Perhaps that's the problem. What are the "permission issues"?
FL2070
Post by FL2070 » Thu Aug 24, 2017 11:41 pm
Administrator permissions. And I've managed to fix the problem myself, it was a problem with parental controls software. Thanks for your help, and sorry for bothering you.
airman
Operating System: Windows 7
Post by airman » Fri Aug 25, 2017 11:03 am
I have the same problem :idea:
