Wont Record From umc 204HD
greenxman
Post by greenxman » Wed Aug 09, 2017 4:32 pm
I recorded from my behringer umc204hd yesterday and it worked fine. Today tried recording get error cahange device change host etc when it was plug and play up to today. it is audacity or my unit
Re: Wont Record From umc 204HD
Post by steve » Wed Aug 09, 2017 4:37 pm
The USB device should be connected before you launch Audacity.
After launching Audacity, ensure that you have the correct device selected in the device toolbar.
