Record and Pauze button
Jos Ector
Post by Jos Ector » Sat Aug 05, 2017 8:20 am
Hello
When I push the rdecord button to start a recording, the pauze-button is automatically selected. So recording is stops immediately.
Who can help me please?
Thanks
Jos
Re: Record and Pauze button
Post by kozikowski » Sun Aug 06, 2017 1:20 am
Which Audacity are you using? the current one is 2.1.3.
http://www.audacityteam.org/download/windows/
What are you recording? Are you using network connections or drives for storage?
Has this ever worked?
Restart the machine and don't let it connect to your internet when it wakes up. Do Shift-Shutdown instead of the regular shutdown. It will take longer, but reset everything as it goes. Then restart.
waxcylinder
Post by waxcylinder » Wed Aug 09, 2017 11:14 am
Have you got Sound Activated Recording accidentally turned on in the Transport Menu:
manual.audacityteam.org/man/transport_menu.html
