Hi
After opening a file and selecting a part of it. I want to export the selected section, but the export option is grayed out not allowing me to perform the operation. Any thoughts? Thanks
Select and Export
Re: Select and Export
Playback needs to be "stopped" and not just "paused". Click the Stop button, then try again. (did I get it?)
Thanks for your help Steve. I think that did it.
mdote
mdote
