Audacity nightly builds.
Re: Audacity nightly builds.
Effect Limiter became to applying 7-8 seconds for 3 minutes track. It is very long, earlier it was 2 seconds. I've even overinstalled Windows, doesn't help. The similar picture with many other effects. Test on your machine and make sure, that I'm right and correct.
Yes I can confirm that effects, particularly Nyquist effects, are much slower in that nightly build.
I think the reason is due to a different version of wxWidgets in that build.
I think this issue should be fixed in the next nightly - please check when it becomes available.
There's a build for 6th August: https://www.fosshub.com/Audacity-Windows-Nightlies.html
It seems, that the situation has improved. Thank you very much!
