Audacity nightly builds.
Re: Audacity nightly builds.
And the same report for Vocal remover:
Notch filter:
What has happened?
Code: Select all
09:58:35: Audacity 2.2.0-alpha-Jul 14 2017
09:58:35: Trying to load FFmpeg libraries...
09:58:35: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
09:58:35: Looking up PATH environment variable...
09:58:35: PATH = 'C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Users\Юрий\AppData\Local\Microsoft\WindowsApps;'
09:58:35: Checking that '' is in PATH...
09:58:35: FFmpeg directory is in PATH.
09:58:35: Checking for monolithic avformat from 'avformat-55.dll'.
09:58:35: Error: Failed to load shared library 'avformat-55.dll' (error 126: не найден указанный модуль.)
09:58:35: Loading avutil from ''.
09:58:35: Error: Failed to load shared library '.dll' (error 126: не найден указанный модуль.)
09:58:35: Loading avcodec from ''.
09:58:35: Loading avformat from 'avformat-55.dll'.
09:58:35: Error: Failed to load FFmpeg libraries.
09:58:35: Error: Failed to find compatible FFmpeg libraries.
09:58:40: File name is C:\Users\Юрий\Music\11 маршрут1.mp3
09:58:40: Mime type is *
09:58:40: Opening with libsndfile
09:58:40: Opening with libmad
09:58:40: Open(C:\Users\Юрий\Music\11 маршрут1.mp3) succeededRe: Audacity nightly builds.
It looks like Audacity can't link to any external applications.
I bet that MP3 export doesn't work either.
No, unlike these effects, mp3 export normally passes. Please, send a normal version, in which all effects work.
There's a new build on FossHub (4th Aug 2017):
https://www.fosshub.com/Audacity-Windows-Nightlies.html
This version is also no good. The effects work, but very slowly, more slowerly than before. Please, correct.
You've not given enough information for us to begin analyzing your problem.юра00 wrote:This version is also no good. The effects work, but very slowly, more slowerly than before. Please, correct.
Please give precise details, including comparisons with the same files on the same hardware with Audacity 2.1.3 release version.
Also, please give details of your equipment.
No, I'll wait for the version on the old nightly builds site, when it's released. And now it's useless, nothing happens.
I don't think there will be any more nightly builds on that site. The nightlies were planned to be moved to FossHub before the old site went down, but that didn't happen due to the guy doing it going into hospital.юра00 wrote:I'll wait for the version on the old nightly builds site
The official release version is the supported version and recommended for production use: http://www.audacityteam.org/download/windows/
