Audacity nightly builds.
юра00
Post by юра00 » Fri Jul 28, 2017 4:20 pm
Fail to open page with audacity nightly builds.
Code: Select all
gaclrecords.org.uk/win-nightly
Please, tell correct adress.
Error message, when try to open:
Code: Select all
Error in log on line 164.
./audacity-win-ra45f3bb-2.2.0-alpha-22-jul-17.zip is already defined.
Re: Audacity nightly builds.
Post by steve » Fri Jul 28, 2017 5:14 pm
That's the correct address, but there appears to be a problem at the moment.
юра00
Post by юра00 » Sat Jul 29, 2017 10:26 am
By the way, the situation did not improve.
юра00
Post by юра00 » Tue Aug 01, 2017 12:26 pm
What, now there will be no alpha versions? So the nightly builds does not work.
Post by steve » Tue Aug 01, 2017 2:47 pm
You know how it is; if it's not one thing it's another.
We had no Mac nightlies for while and I've just got them up again, but now the Windows nightlies are off.
I'll update this topic when I have accurate information.
юра00
Post by юра00 » Wed Aug 02, 2017 5:05 pm
Well, which was the last one? Please send the link to download.
DjDiabolik
Post by DjDiabolik » Thu Aug 03, 2017 11:29 am
mmmmmmmmm.. actually i see there's a new daily build site... but apparently so many version it's not present ? For example on my last usage i have this:
audacity-win-ra68f7fc-2.2.0-alpha-22-apr-17.zip
On new site the latest daily build it's the 2.1.3 of febraury........i have also see the newest github...... the 2.2.x developing continue on it ? We need to compile manually ?
Post by steve » Thu Aug 03, 2017 12:33 pm
Unfortunately Windows Nightly builds are not currently available because the person that was building them is in hospital and the machine that was building them has gone down. I hope that we will be able to bring back regular nightly builds of Audacity development code, but for now the only option if you want the latest alpha version is to download the source code from GitHub and build it yourself. The source code is available here: https://github.com/audacity/audacity
I will update this page as and when new information becomes available.
Post by steve » Thu Aug 03, 2017 12:36 pm
The most recent Windows Nightly build currently available is:
audacity-win-x9072628-2.2.0-alpha-14-jul-17.zip
https://www.fosshub.com/Audacity-Windows-Nightlies.html
I'm hoping that a more recent build can be added soon.
юра00
Post by юра00 » Fri Aug 04, 2017 6:38 am
Download this (audacity-win-x9072628-2.2.0-alpha-14-jul-17.zip) version, the effect Limiter doesn't work. Please, correct.
