i am trying to install audacity software to my windows pc but it is showing some error.
Unable to find the solution, can anyone help me with the solutions
i am unable to use audacity in my pc
bendrajamss
Re: i am unable to use audacity in my pc
What's the problem?
bendrajamss
thanks for the response, steve
it is showing that some file missing. it may be the issue of download file, i use this resource [link removed by moderator: downloadwab]
hey, can le me know the originally link to download the setup file. And also provide me any tutorial or guide for installation
Don't download Audacity (or other software) from third party websites. Always go to the official website, which in the case of Audacity is here: http://www.audacityteam.org/download/
Third part download sites are notorious for spreading adware, malware and viruses.
bendrajamss
thank you for your response, and providing me the original link to download
