Loss of sound quality when using metronome/rhythm track
thad.collins
Operating System: Windows 7
Post by thad.collins » Thu Jul 27, 2017 6:38 pm
When I try to record using a metronome/rhythm track, the sound quality of my guitar recording is awful. Without a metronome/rhythm track it is ok. I am using 2 tracks.
Re: Loss of sound quality when using metronome/rhythm track
Post by kozikowski » Thu Jul 27, 2017 11:11 pm
You're overdubbing, right? Eventually, you'll be playing all six instruments in a song, one on top of the other?
One of the exercises you're supposed to do before you start clicking, rhythming and overdubbing is make a straight, normal, uncomplicated recording. Does that work? I bet it doesn't.
How did you connect your guitar to the computer? Describe how you did it. Pretend I'm holding a guitar and a fist of cables. What kind of computer?
