>> My operating system is : Windows 10 - 64 bits and the Audacity manual help file is .ZIP
I have just downloaded the new version of Audacity 2.1.3 and tried to install the help manual .
No problem with the program but the manual does not work.
After following your instructions for using the online Calculator I found the following différences :
a) Announced Values
Manuel Audacity - 19,72 MB | Version: 2.1.3
SHA256: 35a8f989ac8dfd24fa73716498feeffb82f838972280623309a557a3fa632a88
b) Obtained results
Manuel Audacity - 19,72 MB | Version: 2.1.3-1.zip
SHA256: 1c845bd568dee774bdf855281c6fb3ff6a368fb56f7a6377393f5bf1153fbbec
c) PS The values SHA256 for :
LADSPA-plugins-Win-0.4.15.exe
Audacity-Win-2.1.3.exe
>> are OK
Sincerely, Andre_T
Calculation on :Audacity Manual-2.1.3-1.zip >>does not match
A_Tsampalas
Re: Calculation on :Audacity Manual-2.1.3-1.zip >>does not m
Thanks for letting us know.A_Tsampalas wrote:a) Announced Values
b) Obtained results
I "think" the problem is (I'll check), is that Audacity was originally released with the 2.1.3 version of the manual, but an important error was found and the manual had to be re-released as 2.1.3-1. So both checksums are probably correct, but the Audacity website needs to have the 2.1.3-1 checksum added.
The correct checksum for the 2.1.3-1 version of the manual is published on the download page at FossHub:
https://www.fosshub.com/Audacity.html/
and that matches your calculated value:
Yes, that's what happened.steve wrote:I "think" the problem is (I'll check), is that Audacity was originally released with the 2.1.3 version of the manual, but an important error was found and the manual had to be re-released as 2.1.3-1
The sha256 should be correct now.
