"Audacity is already running" Error
clyd3ram1
Post by clyd3ram1 » Wed Jul 19, 2017 8:43 pm
Hi. I keep getting this error that says "Audacity is already running" "The system has detected another copy of Audacity is running." The story is I tried to open Audacity but it didn't open. So I tried a second time and this error appeared. I ended the task in the task manager, re-installed Audacity, and rebooted about 3 times. Can someone help me fix this? Thanks.
Re: "Audacity is already running" Error
Post by kozikowski » Wed Jul 19, 2017 11:20 pm
When you reinstalled Audacity, did you check the place that says Reset Preferences and Settings? That may not help, but plain installing Audacity does not do a global reset.
First one of these I've seen on Windows. It comes up every so often on Macs by getting a lock file stuck. But I don't know how Windows does it, and a search doesn't either.
Wait for the Windows elves.
Post by kozikowski » Wed Jul 19, 2017 11:22 pm
Did you cold restart? Windows leaves pieces of itself running if you do a normal restart.
Do a clean start from Shift-Shutdown.
clyd3ram1
Post by clyd3ram1 » Thu Jul 20, 2017 1:35 am
OMG It worked! Thanks for your help.
