Skill Test for Audacity Masters,possible Project recruitment
Permanent link to this post Posted by britishgsm » Mon Jul 17, 2017 4:46 am
The Task is simple, the below audio file contains a high pitch ringtone from a cellphone, with low voices in the background and sound.
The low voice that needs to be recovered is under the high pitched ringtone you will hear when you play the attached audio file.
You need to know:
the gender(s) of person(s) in the background.
If anyone has enough skills to completely remove the phone ringtone without damaging the background voices, I might hire you for a few similar tasks, and you will get generously paid for it.
Best Regards
audacity project.wav
(660.38 KiB) Downloaded 7 times
britishgsm
Re: Skill Test for Audacity Masters,possible Project recruit
Permanent link to this post Posted by steve » Mon Jul 17, 2017 8:27 am
This "test" is a waste of time. Any voices present are so deeply buried below other sounds that they are inaudible. If you have money to waste you could hire the services of an audio forensics professional.
Permanent link to this post Posted by Trebor » Mon Jul 17, 2017 7:04 pm
britishgsm wrote:The low voice that needs to be recovered is under the high pitched ringtone you will hear when you play the attached audio file.
ATTACHMENTS audacity project.wav (660.38 KiB)
IMO there's no speech whatsoever on that. The deep noise is the phone's vibrate buzzer noise.
Noises processed by a phone codec designed for speech end up sounding like speech, even though no speech is there,
then the brain misinterepets this as speech, aka audio-pareidolia , aka Rorschach-audio.
The giveaway sign that it's pareidolia is that there are not the typical-length sentences: just occasional words/phrases.
If you pitch-shift the vibrate buzzer noise it does sound like a muffled voice repeatedly saying "please",
but no people are involved, its just a mechanical noise ...
vibrating-phone, pitch-shifted, sounds like ''please''.wav
there are no voices on his, ( see "audio pareidolia")
(660.28 KiB) Downloaded 9 times
Trebor
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 8 guests
