is there a plot spectrum without time limit?
Permanent link to this post Posted by nomenomen » Sat Jul 15, 2017 5:27 am
Hi
the limit is 237.8 seconds
thanks
nomenomen
Re: is there a plot spectrum without time limit?
Permanent link to this post Posted by Gale Andrews » Sat Jul 15, 2017 10:58 am
No. If there was, the time limit would then become waiting for the plot to draw on your screen.
Permanent link to this post Posted by nomenomen » Sat Jul 15, 2017 2:13 pm
Gale Andrews wrote:No. If there was, the time limit would then become waiting for the plot to draw on your screen.
Hi Gale
and to have the frequency analisys of the entire audio ,for example a song ,should i use a vst effect?
i don't know any that can scan an entire song they are realtime mostly
thanks Gale
nomenomen
Permanent link to this post Posted by Gale Andrews » Sun Jul 16, 2017 11:57 am
We can't do the search for you. But you can view the whole material in Spectrogram View.
Permanent link to this post Posted by nomenomen » Sun Jul 16, 2017 2:04 pm
Gale Andrews wrote:We can't do the search for you. But you can view the whole material in Spectrogram View.
Hi Gale
thanks for your response and the link
my english is poor
but when i tried to Analyze->plot spectrum ->i got this message
nomenomen
Permanent link to this post Posted by Trebor » Sun Jul 16, 2017 5:24 pm
nomenomen wrote:... but when i tried to Analyze->plot spectrum -> ....
"Spectrogram" rather than "spectrum" , see ...
There are 2 Audacity display options - waveform or spectrogram.gif (1.16 MiB) Viewed 359 times
Trebor
Permanent link to this post Posted by nomenomen » Sun Jan 14, 2018 4:46 pm
hi
yes i know the different between the names
but i would like to know if i can edit and change the preference for plot spectrum , i need it too to check and compare recording with my external dacs
and about
there are other program like waveshop or Wavosaur that can do it , they are no slow and without limit
audacity is my favorite program , can't understand why there is the limit and why it has to be slow
thanks
nomenomen
Permanent link to this post Posted by steve » Sun Jan 14, 2018 7:36 pm
nomenomen wrote:but i would like to know if i can edit and change the preference for plot spectrum
It's not a setting, so you would need to modify the source code and recompile.
nomenomen wrote:i need it too to check and compare recording with my external dacs
Is it not enough to compare a couple of minutes?
If you really need an average over more than 3 minutes, you could analyze the recording in sections, export the results, then use Excel or some other program to average the results.
Return to Windows
Who is online
Users browsing this forum: Bing [Bot] and 15 guests
