Is there any way to "glue" a label to a segment?
WannaBane
Post by WannaBane » Tue Jul 11, 2017 11:57 pm
I do a lot of longform interviews on a range of subjects, and often we loop back around to an earlier topic late in the interview. I'd LOVE to be able to label things in that interview, edit for a while, then cut/paste segments from later in the interview back into the relevant earlier sections.
Say the subject talks about A, B, C, D, then a again, then D some more, then b again, then E, then F, then a bit more of a, etc.
The most sensible workflow is to label everything, so I wind up with a track that looks like...
ABCDaDbEFa
and then, once I've gotten rid of all the extraneous cruft, long silences, etc., edit...
AaaBbCDEF
But I can't, because even if I label "a" and "b" and "a" later in the track, as soon as I make another pass to edit the earlier segment, the labels are entirely out of line. They don't "attach" to the waveforms I've labeled. They're just these not very useful floating points in a separate track.
Is there any way to "glue" a label to a segment, so if I edit earlier in the waveform, the label will shift to follow the part of the waveform it's "attached" to?
Re: Is there any way to "glue" a label to a segment?
Post by steve » Wed Jul 12, 2017 3:37 pm
Don't forget that Audacity is a multi-track audio editor.
It may be better to approach the task as:
Track 1: Aaaa
Track 2: ...Bbbb
Track 3: .......Cccc
When the project is exported, the tracks are mixed down into one file, so that would produce: AaaaBbbbCccc
