Fluctuating latency
Elfgirl1
Fluctuating latency
Post by Elfgirl1 » Sun Jul 09, 2017 9:43 pm
I have a fluctuating latency issues that I can't figure out how to correct.
Re: Fluctuating latency
Post by steve » Sun Jul 09, 2017 10:26 pm
You mean when you are trying to set up latency compensation (http://manual.audacityteam.org/man/latency_test.html) the amount of latency keeps changing? How much is it changing by?
You are aware that if you use a different audio device, or make other changes to the set-up (such as changing the sample rate or sample format) that the latency will change?
Elfgirl1
Post by Elfgirl1 » Mon Jul 10, 2017 6:36 pm
Yes, the latency compensation process doesn't snap it to the right time, just random times.
Post by steve » Mon Jul 10, 2017 6:46 pm
You mean when you are trying to set up latency compensation the amount of latency keeps changing? How much is it changing by?
Elfgirl1
Post by Elfgirl1 » Mon Jul 10, 2017 7:58 pm
Yes, it varies quite a bit each time I perform the latency compensation process.
Post by steve » Mon Jul 10, 2017 8:20 pm
How much is "quite a bit"? If it's more than a few milliseconds, then you probably need better hardware.
