Thin, distorted recordings
Bedub
Post by Bedub » Sat Jul 08, 2017 2:03 pm
I am new to Audacity (2.1.3). I have a newer laptop with Windows 10, a new condenser microphone running through a Focusrite 2i2. Before and during recordings everything sounds great in my headphones. But when I play back, the recording is really thin and distorted. It's unusable. Why? Any hep would be appreciated...thanks.
Re: Thin, distorted recordings
Post by kozikowski » Sat Jul 08, 2017 4:58 pm
Rich questions are good.
What kind?
Of what? Windows has voice processing that hates music.
Trebor
Post by Trebor » Sat Jul 08, 2017 5:03 pm
"Thin, distorted recordings" does sounds like Window's "enhancements" which need to be turned-off for a high-fidelity recording , see ... http://manual.audacityteam.org/man/faq_ ... _tunnel.3F
Bedub
Post by Bedub » Sat Jul 15, 2017 8:03 pm
Thanks. I actually followed the instructions and I am off and running...
https://support.focusrite.com/hc/en-gb/ ... Windows-10
