Monitor voice recording with earphones
Permanent link to this post Posted by scottgallowaysmith » Mon Jul 03, 2017 11:42 pm
Greetings!
I had been using garage band but no longer have access.
I want to use Audacity but there is a slight delay of my voice in the earphones.
What may I do the solve this issue.
Thanks,
Scott
scottgallowaysmith
Re: Monitor voice recording with earphones
Permanent link to this post Posted by kozikowski » Mon Jul 03, 2017 11:57 pm
You lost your Mac and now you're using a Windows machine.
You're listening to machine latency. Your voice is coming out "one computer late." The only way I know to work around that is plug your headphones into your USB microphone or USB microphone adapter.
If you're keen on computer programming and compiling programs, you can recompile Audacity with ASIO support. ASIO can provide greatly reduced echo when you listen in your computer headphones. Unfortunately, Audacity cannot be supplied with ASIO built-it because it's somebody elses software. Same reason we can't supply Audacity with MP3 generation built-in.
viewtopic.php?f=19&t=13990
Permanent link to this post Posted by scottgallowaysmith » Tue Jul 04, 2017 12:51 am
Thank You! Send me your email address and I will send you a complimentary audio book!
[email protected]
scottgallowaysmith
Permanent link to this post Posted by kozikowski » Tue Jul 04, 2017 1:16 am
I deleted your email address. It's a terrible idea to post a hot email address on the forum because of grazers, harvesters and spammers. It's a good way to wipe out your address.
Permanent link to this post Posted by scottgallowaysmith » Mon Jul 17, 2017 7:34 pm
Plugging my headphones into the mike solves the delay but I can not get enough volume
in my headphones! It there a setting on the software. I have tried all I can think of.
scottgallowaysmith
Permanent link to this post Posted by kozikowski » Tue Jul 18, 2017 2:01 am
The whole idea of plugging your headphones into the microphone or interface is that the sound doesn't go through the software. Zero Latency Monitoring. There are no settings to cause delay and echos.
Permanent link to this post Posted by Trebor » Tue Jul 18, 2017 3:39 am
scottgallowaysmith wrote:... but I can not get enough volume in my headphones! ...
There is a hardware fix : a headphone amplifier , or a cheap mixer.
Trebor
Return to Windows
Who is online
Users browsing this forum: No registered users and 13 guests
