Selection.
юра00
Selection.
Post by юра00 » Tue Jun 13, 2017 3:57 pm
How do I get, as earlier, the end of selection to be the end of the track by default? And now it's 0.
Re: Selection.
Post by steve » Tue Jun 13, 2017 4:44 pm
To extend a selection from the cursor position, or to extend a selection, to the end of the track: Shift + K
To extend a selection from the cursor position, or to extend a selection, to the end of the project (all tracks): Shift + End
For other selection shortcuts, see: http://manual.audacityteam.org/man/auda ... ction.html
юра00
Re: Selection.
Post by юра00 » Tue Jun 13, 2017 7:54 pm
Thank you!
юра00
Re: Selection.
Post by юра00 » Wed Jun 14, 2017 4:15 pm
Although, you can press the right arrow. But I asked that the end of the track should be the default, there's nothing to press.
Re: Selection.
Post by steve » Wed Jun 14, 2017 10:21 pm
I'm not sure what you are trying to say. To move the cursor to the end, press the "End" key or the "Skip to End" button
