How To Put Drum Track
abrogard
Post by abrogard » Sun Jun 11, 2017 10:48 am
Can Audacity automatically create a drum track for me? Nothing fancy. Just like beating time, you know? Like when I push the accompany button on my keyboards and it starts beating away an (awful) 3/4 or 4/4 or whatever 'drum' thing....
woops, sorry... I'm using 2.1.2 on win10
Trebor
Re: How To Put Drum Track
Post by Trebor » Sun Jun 11, 2017 12:04 pm
abrogard wrote:Can Audacity automatically create a drum track for me? Nothing fancy. Just like beating time ...
There is a metronome option ... http://manual.audacityteam.org/man/rhythm_track.html
abrogard
Post by abrogard » Sun Jun 11, 2017 11:22 pm
thanks. i haven't looked at it yet but i don't think that's what i want. i want a drum tone spaced correctly for the time signature that i can identify on the timeline and use.... does the metronome do that? i'll check...
Edit: I've found drum samples n the web and have downloaded a stack of them. I've got one drum hit imported into audacity, so that's good. Now, how do I repeat that something like four times a bar for a 32 bar song - like 128 repeats of it equally spaced... ( with every first and third emphasised ? maybe leave that bit for later )
Trebor
Post by Trebor » Mon Jun 12, 2017 4:14 am
abrogard wrote:I've got one drum hit imported int audacity, so that's good.
Precisely* select then repeat.
( * You may need to zoom-in ).
Post by kozikowski » Mon Jun 12, 2017 12:56 pm
There was serious discussion about splitting Metronome and Generate > Rhythm. You want Generate > Rhythm when we get that far.
