Windows 10 Pro, 64-bit
What I want to do is essentially achieved by importing a set of tracks, selecting all, and Amplifying them to a given New Peak Amplitude. So what's the problem? Well of course, when you import multiple tracks and then export them, the exported files' metadata isn't the same as the original files, unless you manually make it so. I have a lot of files to process and I need their metadata to stay intact. If you want to preserve the metadata, you have to use a chain, so I guess I'd better make a chain, right?
But wait! If you use Amplify in a chain, then you can only set the Amplification, not the New Peak Amplitude. So, the best thing I've come up with so far is to import all the files, select all, select Amplify and enter the New Peak Amplitude I want, look at the corresponding Amplification, edit the Amplify chain accordingly, and then finally apply the chain. In terms of the time I spend, it's terribly inefficient compared to just navigating to some files and applying a chain to them. I want to process many separate sets of files, so it would cost me a lot of extra time in the long run.
Of course, Normalize doesn't work for this purpose, because as the Audacity manual states,
So... what are the "many other audio applications" of which the manual speaks? In particular, what are the free ones?Audacity's Normalize effect breaks with the convention of many other audio applications. In those applications, "normalize" maximizes multiple tracks against the peak level common to all of them, so retaining their relative balance.
Or, if there's a sensible workaround in Audacity, I'm open to that too.
