SciTEkozikowski wrote:How are you seeing that?
Aup. file won't open.
Re: Aup. file won't open.
That's probably how you found my CR and LF characters. I can see ^M but nothing else.
- Quality Assurance
Then that could corrupt or destroy other projects in future. Computer crashes are usually driver problems.DutchDubber wrote:My friend's PC crashed right after he saved the project and closed the application.
Ask him to take a look at this FAQ: http://manual.audacityteam.org/man/faq_ ... tml#reboot. Reading the crash dump might help him find the cause of the crash.
The Dropbox app for Windows (Desktop version) can crash if you use that and that can sometimes take the computer down with it. That could still be a problem with a Windows driver, though. Look at the dump.
