Mono back to stereo
Mono back to stereo
Permanent link to this post Posted by theprawn26 » Fri May 19, 2017 4:25 pm
Hi all,
I edited a podcast which was originally in stereo, and mixed and rendered it into a mono track. Problem is there's some background noise on my guest's audio at the same time as me speaking and so i need to unmerge the tracks again to silence it out. How do i unmono a track back to stereo?
Thanks
AM using the most up to date version for windows
theprawn26
Re: Mono back to stereo
Permanent link to this post Posted by steve » Fri May 19, 2017 5:14 pm
Which versions do you have?
I presume that you don't have the original recordings.
If you only have a mixed down mono MP3, then you won't be able to un-mix it.
Permanent link to this post Posted by DVDdoug » Fri May 19, 2017 5:20 pm
If you saved the Audacity project you may be able to "undo" or you can try Make Stereo Track.
If all you have is the mono track, you are out-of-luck... [I]"You can't un-fry and egg or un-bake a cake, and you can't un-mix audio."[/]
DVDdoug
Forum Crew
Permanent link to this post Posted by kozikowski » Fri May 19, 2017 5:45 pm
Audacity Projects do not save UNDO.
Keep original raw recordings as WAV or other uncompressed format.
Permanent link to this post Posted by theprawn26 » Sat May 20, 2017 9:05 am
Ok thanks guys.
One other thing - when I normalize it's left a bit quiet. Current normalize setting is to -1.5. To make it a touch louder should i put it to -2.0 or -1.0? I cant figure out which direction makes it louder
theprawn26
Permanent link to this post Posted by steve » Sat May 20, 2017 9:39 am
theprawn26 wrote:Current normalize setting is to -1.5. To make it a touch louder should i put it to -2.0 or -1.0? I cant figure out which direction makes it louder
0dB is "full scale", so that's the loudest you can get without "clipping" (losing the tops / bottoms of the waveform).
That means that -1.0 is a bit louder than -2.0, but not very much. A change of 1dB is hardly noticeable.
Note that both the Amplify and Normalize effects work on "peak level", so if there is one peak that is higher than the rest of the audio, then that peak is responsible for how much the level can be increased. By reducing stray peaks so that the level is more even, it will be possible to increase the level of the track more without clipping.
Various tools are available for evening out the level. Here's three:
http://manual.audacityteam.org/man/envelope_tool.html
http://manual.audacityteam.org/man/compressor.html
http://manual.audacityteam.org/man/limiter.html
Permanent link to this post Posted by theprawn26 » Sat May 20, 2017 10:50 am
Thanks Steve, I find those written guides really hard to follow. They use terms way above my pay grade. I guess I'd like an easy to follow video guide on what to do when one guest is really loud and another is really quiet and how to even it out.
theprawn26
Permanent link to this post Posted by steve » Sat May 20, 2017 11:19 am
Return to Windows
Who is online
Users browsing this forum: BlueJean, lonepilgrim, waxcylinder and 16 guests
