USE LISP OR SPITFISH
Trebor
Re: USE LISP OR SPITFISH
Post by Trebor » Sun May 21, 2017 9:16 pm
PAOLO58 wrote:... how do i use them to modify parts of the song with hissing .. what exactly should I do?
DeEssers , (like LISP & SpitFish) , are to reduce sibilance in speech, so should only be applied to vocals tracks, (no musical instruments).
If the problem is constant hissing noise, (rather than excessive sibilance), the tool you need is noise reduction , (not de-essing).
PAOLO58
Post by PAOLO58 » Mon May 22, 2017 7:33 am
Thank you. I did not find the user manual or at least a simple guide. I only found the description of the individual commands for LISP.
Post by steve » Mon May 22, 2017 8:27 am
Neither Lisp or Spitfish are our products. We do not have manuals for them and are not able to offer technical support for them. We do provide a manual and technical support for Audacity, but not for third party products.
