" Audacity will open whatever Windows provides. Audacity gets the show from Windows, not the mixer or turntable." Kos
That makes sense, I wondering how I did it before ???
Possibly I need to link a small mixer to pick up the line in / phono ?
As I dont get a signal from the TTs, but I do if I use virtual Dj when i change the configs ... in the past in Audacity, i would press the monitor and could control the volume levels ....
I would like an easy route to be able to get a signal in Audacity without using VDJ, with a volume level I can control ... especially at this time of night ... its pretty loud ...
RRx
Analogue Turntable Issues
Rusty Rebel
- Operating System: Windows 7
Re: Analogue Turntable Issues
VDJ may be conflicting with Audacity or it may be "taking over" the USB connection. So, I recommend you try it without VDJ running.
OK, let's back-up a bit...
Does your mixer (or some kind of "USB" device) show-as your Recording Device in Audacity? (I'm not sure if it's not showing-up, or if you've selected it and you're "recording silence".)
Audacity can't find it, right-click on the Windows Speaker/Volume icon. Navigate to Recording Devices, and try to find the USB mixer. Window has found it, navigate to Properties -> Advanced and make in-check "Allow applications to take exclusive control of this device..
If Windows doesn't see the mixer, of course Audacity won't see it either. You may have to re-install the driver.
If none of that works, there may be something we can do to record
That sound right for VDJ, but to record with Audacity the signal needs to go the other way.... Mixer -> USB -> Computer. You may be able to use it both ways at the same time, but right now we're trying to get the sound from the mixer into Audacity.I have Tosh Sat Laptop leading to Hercules RMX Mixer via usb leading to external speakers.
Rusty Rebel
Thank you for your replys...
Yes, Audacity was picking up the mixer, as mentioned the exclusive use, I have cleared that and yes I get a signal and hear the turntable although it is very low in Audacity ... so getting there. I have used the volumes in Audacity to full but not as loud as other applications ... something is holding back the in Audacity, some kind of setting / configuration possibly.
Maybe this is not the forum, but I will ask anyway how can I control line in connections o my mixer, so I can use all the effects such as Kill frequencies and equalizer ?
- Quality Assurance
Try reading the manual for the mixer.Rusty Rebel wrote:how can I control line in connections o my mixer, so I can use all the effects such as Kill frequencies and equalizer ?
