10 bit, 12 kHz uncompressed no header output
freepiston
Operating System: Windows 7
Post by freepiston » Mon May 15, 2017 12:56 pm
Windows 7
Audacity 2.1.3
I cannot figure how to get a non-compressed file output in 10 bit format with sample rate of 12kHz and with no header. Is it possible using Audacity?
Thanks.
DVDdoug
Forum Crew
Re: 10 bit, 12 kHz uncompressed no header output
Post by DVDdoug » Mon May 15, 2017 2:07 pm
I don't believe so, since computer files are stored in bytes (8-bits) so audio files (all files) are 8, 16, 24, 32-bits, etc.
Post by steve » Mon May 15, 2017 2:09 pm
Audacity does not have built-in support for 10-bit export.
That's a very strange format - what's it for?
Post by Gale Andrews » Mon May 15, 2017 2:18 pm
Is this something your science teacher asked for? Might they have meant 8-bit?
Or do you mean NICAM?
Do you have an application that can play the file you want to export?
freepiston
Post by freepiston » Mon May 15, 2017 6:03 pm
Oh to be young enough to have a teacher!
I want to program an Atmel 8 bit processor in 10 or 12 bit format with sample rate of 12kHz. I can make the digitising circuit but though I could cut corners by using a Windows application.
Post by Gale Andrews » Mon May 15, 2017 6:18 pm
I guess you could try SoX with the -b parameter: http://sox.sourceforge.net/sox.html. It is a command-line application.
Downloads are at https://sourceforge.net/projects/sox/files/sox/.
Post by steve » Mon May 15, 2017 6:48 pm
12 kHz sample rate is simple enough. Just set the "Project Rate" (lower left corner of the main Audacity window) to 12000, then export as WAV.
For 10 or 12 bit, you can export from Audacity as 16-bit WAV, and ignore 6 or 4 LSBs when you read the data into your device.
Gale Andrews wrote:I guess you could try SoX with the -b parameter: http://sox.sourceforge.net/sox.html. It is a command-line application.
As far as I'm aware, neither SoX or FFmpeg support 10-bit encoding.
Post by Gale Andrews » Mon May 15, 2017 7:42 pm
steve wrote:For 10 or 12 bit, you can export from Audacity as 16-bit WAV, and ignore 6 or 4 LSBs when you read the data into your device.
I thought of that, or possibly manipulation in MATLAB, but are there universal commands for ignoring least significant bits (LSBs)?
DVDdoug
Forum Crew
Post by DVDdoug » Mon May 15, 2017 8:02 pm
Actually, if you export to RAW you'll get a file without a header.
Export Audio
Save as type: Other uncompressed files
Header: Raw (Header-Less)
Encoding: Signed 16-bit PCM
Then, ignore the "extra" LSBs in your Atmel code.
freepiston
Post by freepiston » Mon May 15, 2017 8:05 pm
Thanks all for your quick and helpful advice. Steve, I'll go with your simple solution. :D
