best freeware for bass lines to use in Audacity
nivedan80
Post by nivedan80 » Sun May 07, 2017 7:41 pm
I'm using Audacity 2.1.3 on windows 8.1 pro.Which is the best freeware to create bass lines so that I can use it in Audacity,like for drums I use Hydrogen which have been good till now and easy to use too.Could you kindly suggest.Honestly, I do not have the means to buy a software :) .I obtained Audacity via a .exe installer
Trebor
Re: best freeware for bass lines to use in Audacity
Post by Trebor » Mon May 08, 2017 1:35 am
