"could not create autosave file"
Xerlome
Operating System: Windows 7
Post by Xerlome » Sun Apr 16, 2017 2:22 pm
Windows 7
Audacity 2.1.1
When I do a usual amplification, the message now always comes, "could not create autosave file". The amplifications are successful. What is wrong?
I find that the error message comes with any change or edit I make in the project. It doesn't happen on another project I have open.
Re: "could not create autosave file"
Post by Gale Andrews » Mon Apr 17, 2017 12:15 pm
Export the project or each track therefrom as WAV.
Import the WAV files into a new project and save that as a new Audacity project with a different name.
Upgrade to Audacity 2.1.3 from http://www.audacityteam.org/download/windows.
Xerlome wrote:Windows 7
Audacity 2.1.1
weitzhandler
Post by weitzhandler » Mon Mar 18, 2019 6:54 am
I have been facing the same issue in version 2.3.1 in Windows 10.
I managed to solve those issues by adding Audacity to the authorized apps list, following the following instructions.
- Search start menu for "Controlled folder access" and open its settings
- Click "Allow an app through Controlled folder access", and add Audacity
- Problem is gone
HTH
