'inserting' in the middle of a track
ANMB
Post by ANMB » Thu Mar 30, 2017 4:41 pm
Good Afternoon.
I am working on combining two tracks: one is in a foreign language and the other is the translation of that first track. When combined, it is a very long track (11 minutes) that has a segment spoken in a foreign language followed by the translation of that same segment. I also have labels for each segment (on all tracks) to keep them easily identified between segments of each language; and I just noticed a mistake at the beginning of the combined track. What I need to be able to do in an efficient way is to "insert" a blank segment, so I can copy/paste both the corrected translation and label, while keeping all other segments and labels together. When I attempted to use the 'sync-lock tracks' and highlighted both the track and label regions and then 'generate silence', it added the silence to the track, while the corresponding labels remained in place.
How do I 'insert' a segment or silence, while keeping both the track and labels synced and shifting together after the point of 'insertion'/generation/pasting, please?
Thank you.
*** EDIT: I just updated the software and tried it again and the track segments seem to be synced to the labels now. :D I was fretting over having to realign the labels, as it is very time consuming, and i want to be done with this particular track after 3 days worth of work on it.
Now, I need to be able to reverse the segments so we hear the translation followed by the Arabic language segment; what is the most efficient way to do so? I have two tracks in the same file: one Arabic and one English translation, both with labels; and the combined track of Arabic followed by English.
Should I 'highlight' and 'duplicate' each segment and then use the 'time shift tool' for many additional tracks? There are 39 segments for each track (Ar & En). Or should I just 'highlight' and 'copy/paste' and add another label in an additional track?
Re: 'inserting' in the middle of a track
Post by steve » Thu Mar 30, 2017 7:16 pm
How many questions?
This is very confusing for anyone trying to help. For future reference, please keep to ONE question per forum topic.
ANMB wrote:How do I 'insert' a segment or silence, while keeping both the track and labels synced and shifting together after the point of 'insertion'/generation/pasting
To create a space within an audio clip:
1) Click on the audio clip at the point where you wish to insert the gap
2) If there are multiple audio tracks, do: "Edit menu > Select > In all tracks" (shortcut Shift + Ctrl + K)
3) "Split" the audio clip(s) "Edit > Clip Boundaries > Split" (Ctrl + i)
4) Now click and drag a selection region across all tracks so as to cover all audio clips and labels that occur after the split point.
5) Switch to the Time Shift tool (http://manual.audacityteam.org/man/time_shifting.html)
6) Click insider the selected region and drag to the right.
ANMB
Post by ANMB » Thu Mar 30, 2017 9:02 pm
My apologies for any confusion. And I will post the other question/s as a different forum topic.
Thank you for the explanation of inserting in the middle of a track. Since I am a novice user and am unfamiliar with the method of 'splitting and clipping boundaries', I will read more here:
http://manual.audacityteam.org/man/auda ... clips.html
