Simple way to jump to a point? [SOLVED]
1980-f
Operating System: Windows 7
Post by 1980-f » Tue Mar 28, 2017 10:49 am
This should be simple: I want to know a straightforward way to move the cursor from the start of a track to a particular time position, such as 6 mins 54 secs. How, please?
(Windows 7, Audacity 2.1.2)
Re: Simple way to jump to a point?
Post by steve » Tue Mar 28, 2017 11:42 am
Type the required time position into the Selection Toolbar "Selection Start" box. http://manual.audacityteam.org/man/sele ... olbar.html
If you can't see the start of the selection after doing that, press "Ctrl + [" (hold down the Ctrl key and press the left square bracket key). This is the keyboard shortcut for:
"View menu >Go to Selection Start"
Post by steve » Tue Mar 28, 2017 11:44 am
1980-f wrote:(Windows 7, Audacity 2.1.2)
The current (recommended) version is Audacity 2.1.3. You can get it here: http://www.audacityteam.org/download/windows/
1980-f
Re: Simple way to jump to a point? [SOLVED]
Post by 1980-f » Tue Mar 28, 2017 11:48 am
Thank you Steve, That works just fine. :D
