Best way to install 2.1.3
edwinn
Operating System: Windows 7
Post by edwinn » Mon Mar 27, 2017 11:20 am
Glad to see this long-awaited update. I have 2.1.2 installed with a mix of 2.1.3 alpha build files, and with custom shortcut keys defined.
What's the best route to get 2.1.3 running? Install in a separate folder? I'd rather not install over 2.1.2 right now, just in case.
Thanks,
-Ed
waxcylinder
Re: Best way to install 2.1.3
Post by waxcylinder » Mon Mar 27, 2017 12:22 pm
In which case I'd install it to a separate folder - as a QA tester I have many many folders with Audacity versions (going all the way back to 0.8 and 0.98b).
All work fine - but only one instance can be run at a time - so only one version at a time.
edwinn
Post by edwinn » Mon Mar 27, 2017 4:20 pm
Ok, it's installed in `Audacity 2.1.3´ folder. Also copied the lame_enc.dll file into `Plug-Ins´ and made a folder `ffmpeg´ and populated that from the Zip. Seems the custom hotkeys are working just fine. Looks like it's all set to go.
In a few days or weeks, I'd like to Uninstall 2.1.2 with alpha components (not beta) and Reinstall official 2.1.2 release.
Question: Just reinstall 2.1.2 in the original folder and forget about uninstalling? what about custom settings?
Thanks,
-Ed
Post by Gale Andrews » Mon Mar 27, 2017 5:31 pm
edwinn wrote:I have 2.1.2 installed with a mix of beta build component files
What does that mean? Are you running 2.1.2 out of a folder that also contains Audacity 1.3.<something>?
Post by Gale Andrews » Mon Mar 27, 2017 5:33 pm
edwinn wrote:Question: Just reinstall 2.1.2 in the original folder and forget about uninstalling? what about custom settings?
Your settings are in Users\<username>\AppData\Roaming\Audacity\audacity.cfg. Those settings don't change unless you delete audacity.cfg or reinstall Audacity with "Reset Preferences" enabled.
There is no need to uninstall before installing into the same folder.
edwinn
Post by edwinn » Mon Mar 27, 2017 5:40 pm
Gale Andrews wrote:
edwinn wrote:I have 2.1.2 installed with a mix of 2.1.3 alpha build files..
I have 2.1.2 in `Program Files (x86) \ Audacity´ folder with 2.1.3 alpha files.. and now running 2.1.3 out of `Program Files (x86) \ Audacity 2.1.3´ folder.
Thanks,
-Ed
Post by Gale Andrews » Mon Mar 27, 2017 5:47 pm
If you want to keep both 2.1.3 release and 2.1.2 release for now, I would clean up that 2.1.2 folder by installing 2.1.2 into it: http://www.oldfoss.com/Audacity.html.
edwinn
Post by edwinn » Sat Apr 01, 2017 9:00 pm
Everything is working ok with 2.1.3 so far (I think) and I'm intending to uninstall 2.1.2 which is in a separate folder.
However only 2.1.3 shows up Programs and Features. How best to uninstall 2.1.2?
-Ed
Post by Gale Andrews » Sun Apr 02, 2017 12:09 pm
edwinn wrote:Everything is working ok with 2.1.3 so far (I think) and I'm intending to uninstall 2.1.2 which is in a separate folder.
Run "unins000.exe" in the 2.1.2 folder.
