Audacity not detecting recording device
Permanent link to this post Posted by Zoroastroman » Mon Mar 20, 2017 9:02 am
I've been recording with Audacity 2.1.2 and a Behringer 1202 mixer on Windows 7 for some time, but for some reason it's no longer detecting the microphone I have hooked up to it.
Nothing has changed as far as I'm aware, no updates and all connections appear as normal. I've also reinstalled Audacity, but same problem.
I've looked at the FAQs concerning this, but it doesn't quite explain my problem other than suggesting the drivers might need replacing.
Any help would be appreciated.
Thanks
Zoroastroman
Operating System: Windows 7
Re: Audacity not detecting recording device
Permanent link to this post Posted by steve » Mon Mar 20, 2017 9:54 am
The device should be connected to the computer, and working, before you launch Audacity,otherwise you will need to tell Audacity to rescan for available audio devices.
With Audacity entirely closed and the device connected, look in the Windows Sound control panel (http://wiki.audacityteam.org/wiki/Mixer ... es#vistacp) and ensure that the device is enabled in the recording tab, and that the meters jump up and down when you talk into the mic. When that's working, launch Audacity and ensure that the device is selected in the Device Toolbar (http://manual.audacityteam.org/man/device_toolbar.html).
(See also, "Rescan Audio Devices" http://manual.audacityteam.org/man/tran ... tml#rescan)
Permanent link to this post Posted by Zoroastroman » Mon Mar 20, 2017 9:57 am
Done all that mate, but no joy.
Zoroastroman
Permanent link to this post Posted by kozikowski » Mon Mar 20, 2017 10:42 am
What's the microphone?
You left us some fuzzy words there. If you scratch or speak into the microphone, do the sound meter lights on the mixer flash? Can you hear the sound if you plug headphones into the Behringer? Forget Audacity for a minute. Let's get basics down.
The 1202 is an analog mixer. How are you getting the sound into the computer and what is the computer?
Reinstalling Audacity doesn't reset Audacity. The Windows installer should have had a setting asking you to reset Preferences and Settings. Did you say yes?
Permanent link to this post Posted by Zoroastroman » Mon Mar 20, 2017 10:51 am
kozikowski wrote:What's the microphone?
The microphone is a Shure 58 and both it and the mixer seem to be working fine - mixer lights do flash, headphones okay.
However, I'm not sure I did reset preferences and settings now that I come to think of it.
To complicate matters, the PC I'm using at home isn't hooked up to the internet so I needed to download Audacity on my work PC then reinstalled it as a shortcut on the home PC so maybe that's the issue.
I'll check that first.
Thanks for your help.
Zoroastroman
Permanent link to this post Posted by kozikowski » Mon Mar 20, 2017 11:11 am
All that and Audacity gets its sound from Windows, not the sound connection, so look in the Win7 control panels and make sure you can see the connection (you didn't say what it was) and the little sound meters bounce.
If you're using a USB interface (I have one machine which works like that), Audacity checks for connections when it starts. Connect everything and then start Audacity, or Transport > Rescan.
Permanent link to this post Posted by steve » Mon Mar 20, 2017 11:14 am
Zoroastroman wrote:Done all that mate, but no joy.
Do you see the meters jumping up and down in the Windows Sound Control Panel?
What are your settings in Audacity's Device Toolbar?
Permanent link to this post Posted by steve » Mon Mar 20, 2017 11:15 am
Zoroastroman wrote:The microphone is a Shure 58 and both it and the mixer...
How is the mixer connected to your computer?
Permanent link to this post Posted by Zoroastroman » Mon Mar 20, 2017 11:23 am
Thanks fellas - I'll check all that when I get home
Zoroastroman
Permanent link to this post Posted by kozikowski » Mon Mar 20, 2017 6:40 pm
Without question the most common problem is a USB device, Windows and Audacity losing track of each other. When you come back up, please mention the connection process. That can make a big difference.
Next
Return to Windows
Who is online
Users browsing this forum: Bing [Bot], Exabot [Bot], Google [Bot] and 10 guests
