Win7 x64 Audacity 2.1.3 Side by Side Conflict Errors
Re: Win7 x64 Audacity 2.1.3 Side by Side Conflict Errors
Post by steve » Wed Aug 02, 2017 9:50 am
Melchior wrote:and was checking my Windows System Event logs and came across the SideBySide errors.
Is it actually a problem with regard to Audacity functioning correctly?
Melchior
Operating System: Windows 7
Post by Melchior » Wed Aug 02, 2017 4:11 pm
steve wrote:
Melchior wrote: and was checking my Windows System Event logs and came across the SideBySide errors.
None that I can see at the moment...
Audacity isn't crashing over it...
Type : Error
Date : 8/2/2017
Time : 3:00:38 AM
Event : 80
Source : SideBySide
Category : None
User : N/A
Computer : Sage-of-Life2
Description:
Activation context generation failed for
"C:\Program Files (x86)\Audacity\audacity.exe".
Error in manifest or policy file "" on line.
A component version required by the application conflicts with another component version already active.
Conflicting components are:.
Component 1: C:\Windows\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_fa3b1e3d17594757.manifest.
Component 2: C:\Windows\WinSxS\manifests\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_41e855142bd5705d.manifest.
I have attached the two manifest files...
Windows_manifest_2files.zip
(2.7 KiB) Downloaded 65 times
neophyte43
Post by neophyte43 » Tue Aug 29, 2017 10:04 pm
Hi,
A temp solution -- this is not my line of work so I'm not responsible if you choose to do what I did. I would appreciate assistance in trying to keep the problem code lines I deleted by commenting them out instead.
Audacity.exe file was edited using trial version of Resource Tuner to remove 6 code lines fm the manifest file as follows:
Make copy of original audacity.exe file and use a temp work space. Open Tuner/open file/drill to manifest/click on English US -- then edit manifest {see CUT**((....))**:CUT}.
<?xml version='1.0' encoding='UTF-8' standalone='yes'?>
<assembly xmlns='urn:schemas-microsoft-com:asm.v1' manifestVersion='1.0'>
<trustInfo xmlns="urn:schemas-microsoft-com:asm.v3">
<security>
<requestedPrivileges>
<requestedExecutionLevel level='asInvoker' uiAccess='false' />
</requestedPrivileges>
</security>
</trustInfo>
<dependency>
<dependentAssembly>
<assemblyIdentity type='win32' name='Microsoft.Windows.Common-Controls' version='6.0.0.0' processorArchitecture='x86' publicKeyToken='6595b64144ccf1df' language='*' />
</dependentAssembly>
CUT**(( </dependency>
<dependency>
<dependentAssembly>
<assemblyIdentity type='win32' name='Microsoft.Windows.Common-Controls' version='6.0.0.0' processorArchitecture='*' publicKeyToken='6595b64144ccf1df' language='*' />
</dependentAssembly>))**CUT
</dependency>
</assembly>
Save file or save as is -- place edited file in audacity directory. At this time you will need to remove and suggest save the original file somewhere for future use. Rename edited exe or use it as is to start Audacity. A new shortcut will also be needed to match the edited exe file.
Let me know if this helps anyone...........
W10Pro 64 bit
VIA HD Audio(Windows 10)
AT-LP120-USB
lmstearn
Post by lmstearn » Tue Sep 05, 2017 6:57 am
Hi there, also get this but not particularly worried about the log. Just wondered if it will be addressed for next release.
Thanks for reading!
baskins
Post by baskins » Mon Sep 24, 2018 2:58 am
Has anyone resolved the error message? It doesn't seem to affect anything, but in trying to get support for another app issue, they keep saying that I've got problems with my Windows 10 install. I tried to follow a link in a previous response, but got error doing that.
Appreciate any help!
Post by steve » Mon Sep 24, 2018 7:58 am
Audacity 2.1.3 is obsolete. You should upgrade to the current version.
waxcylinder
Post by waxcylinder » Mon Sep 24, 2018 9:44 am
Yes, this has been fixed for the soon to ne upcoming 2.3.0 release.
See this entry from our bugtracker: https://bugzilla.audacityteam.org/show_bug.cgi?id=1776
