In my search to hotkey the world I am wondering if anyone has figured out a clever way to:
- hotkey a particular EQ effect inside the EQ menu
- hotkey switching between Waveform and Waveform DB in the timeline?
TIA!
basic hotkeys question
- Quality Assurance
Re: basic hotkeys question
You can see what Audacity shortcuts are available if you open Keyboard Preferences.sartre245 wrote:In my search to hotkey the world I am wondering if anyone has figured out a clever way to:
If the track has the yellow focus border, SHIFT + M then V to change to Waveform. Use UP or DOWN arrow if the track does not have the yellow focus border.
Presumably you already use AutoHotkey or similar? You would want that for a one step shortcut to choose a preset EQ curve.
Thank you, Gale!
