unable to create these tones
DMZ
Operating System: Windows 7
Post by DMZ » Thu Mar 16, 2017 2:21 pm
hi
im intersted in the binaural beats .however i found out that isochronic tones are more effective
i downloaded isomod and i put it in plugins folder
now my problem is i create the carrier tone but in modulation frequency i wanna write 30 but i just i can put untill 20
what can i do ??
Re: unable to create these tones
Post by Gale Andrews » Thu Mar 16, 2017 2:32 pm
DMZ wrote:hi
what can i do ??
You can open the Isomod.ny file in a text editor and change these two lines as indicated:
Code: Select all
;control startf "Initial Modulation Frequency" real "Hz" 7 1 30
;control endf "Final Modulation Frequency" real "Hz" 2 1 30
Standard disclaimer: any harm you do to yourself as a result of using this plugin or changing its settings is entirely your responsibility.
DMZ
Post by DMZ » Thu Mar 16, 2017 2:35 pm
thanks man you helped me alot
it was about 2 days i was try fixing this
DMZ
Post by DMZ » Thu Mar 16, 2017 2:39 pm
sorry again
what king of harm it could have if i do this ??
it would harm which part ??
Post by Gale Andrews » Thu Mar 16, 2017 2:52 pm
DMZ wrote:sorry again
It is just a standard disclaimer that your brain could be affected, in the same way that if we were adding white flashes into a video your brain could be affected. See Brainwave entrainment.
DMZ
Post by DMZ » Thu Mar 16, 2017 3:22 pm
oh my god really
it seem you are so much pro
can you teach me things about this subject ??
where i can chat with you to do ?
Post by Gale Andrews » Thu Mar 16, 2017 3:31 pm
Why do you want to create binaural beats in the first place, if not to affect your mind? ;)
I am not a "pro" and I know nothing and believe nothing about brainwave entrainment. There are forums online though where you may be able to discuss the theories involved.
DMZ wrote:oh my god really
DMZ
Post by DMZ » Thu Mar 16, 2017 3:39 pm
why do or why dont ??
binaural beats are so much intersting but not effective as isochronic tones but i used to create these types of beats for a person who wanted growth hormone
whats your idea isochronic or binaural !?
can you tell me which frequency give me the maximum awareness and inspiration for arts ???
some are claiming gamma and some theta and alpha
what is your idea about this ?
Post by Gale Andrews » Thu Mar 16, 2017 3:47 pm
As I said, we will not discuss these theories on Audacity Forum. We can only tell you how to do something that these theories may tell you to do.
Please use your favourite search engine to find forums or chat rooms where you can discuss these theories with believers.
DMZ wrote:why do or why dont ??
EAM
Post by EAM » Sun Mar 31, 2019 7:17 pm
I've made several modifications to the IsoMod plugin to give you better control over the envelope shape.
https://github.com/ElliotMebane/IsochronicToneGenerator
